finding the distance downstream
1230
02-13-2017 01:37 PM
AnneWynn
I need to find the distance (from sampling points on a stream network) downstream to the mouth of a watershed using NHD flowlines and/or a DEM.   I do not know how to use code. Thanks for any help on this!
DuncanHornby
MVP Notable Contributor
As you explicitly state you do not use code then your only option is to develop up a work flow in model builder using network analyst or use specialist tools such a ArcHydro or RivEX which are designed to trace along vector river networks
