Finding All Geodatabases Inside Main Folder and Subfolders
7331
11
07-23-2010 06:41 AM
JeremyKoontz
Good morning everyone,
I am working on trying to figure out how to create a list of full-path geodatabases that are inside a user-given folder.  I would like it to be able to look down into any number of subfolders to find geodatabases ( I.E. if the main folder is "D:\Data\, I would like it to find a geodatabase that is located in "D:\Data\this\is\my\deep\subfolder\path\something.gdb" ).  I currently have it working to pick up all personal databases by using regular expression matching, but the file geodatabases are giving me a lot of trouble.  Here is the code that I have so far:
for root, dirname, filenames in os.walk ( folder ):
    for file in filenames:
        if ( re.match ( "([A-Za-z0-9_]*).gdb", file ) ):
            geodatabases.append ( os.path.join ( root, file ) )
        elif ( re.match ( "([A-Za-z0-9_]*).mdb", file ) ):
What its doing is that it will find all of the files that are in the file geodatabase folder (which are conveniently named *.gdbindex and such, which are caught by my regular expression) and put those in the list.  I just want it to be able to figure out that it is a file geodatabase and put the path of the geodatabase in the list.
Thank you for your time!
Jeremy
ChrisSnyder
Honored Contributor
Maybe try looking for the standard PGDG tables inside the .mdb. For example, all PGDBs have a table called GDB_ReleaseInfo.
LoganPugh
Is there a way to do this without using a 3rd party OLEDB/Jet library? The arcgisscripting ListTables command doesn't list those tables.
