Filling gaps in polygons
18985
5
11-15-2013 03:37 AM
KaiB_
Hi there,
I have a shape-file with 10.000 polygons, some of them have little gaps (0,5 * 0,5 meters). Is there a way/process to fill these gaps automatically?
Thank you in advance, Kai
DuncanHornby
MVP Notable Contributor
Does your dataset have larger holes or are they always .5x.5? Do you want to remove ALL holes or just the small ones?
KaiB_
the dataset has holes in different sizes, I would like to fill all holes > 1 m².
Best regards, Kai
DaleHoneycutt
Sounds like the Eliminate Polygon Part tool will do what you need.
ChrisSnyder
Honored Contributor
Also, the Union tool with the NO_GAPS option along with a subsequent Dissolve will also fill gaps in polygons.
KaiB_
Thank you very much ,
it worked with the eliminate-tool.
For others: Please be aware to use that tool with data in a file geodatabase; I had some problems (some gaps were not filled) when I used shape-files.
