Field calculation issues
1357
07-07-2021 12:00 PM
KatHoenke
I'm trying to calculate a field from another field using arcpy. If the field contains the word Diversion, I want it to calculate the other field with the value 3. If it conctains 'Dam' I want it to calculate 9, otherwise keep it null.
When I try to execute this in the python window, itlooks like it's working, but my field is still null. The new field is a long integer. Please Help!
Category = "StructureCategory"
expression5 = "Reclass(!StructureT!)"
codeblock = """def Reclass (newdams_schema):
    if 'Diversion' in newdams_schema:
        return 3
    elif 'Dam' in newdams_schema:
        return 9
    else:
        return None"""
# Execute CalculateField
arcpy.CalculateField_management(newdams_schema, Category, expression5, "PYTHON_9.3")
DanPatterson
MVP Esteemed Contributor
are you doing this in arcmap or arcgis pro? (because PYTHON3 is used in Pro)
I think you missed codeblock.
Also, you don't need to return None and you can format your codeblock as
codeblock = """
        return 3
        return 9
    else:
        return
arcpy.management.CalculateField(newdams_schema,
                                field=Category,
                                expression=expression5,
                                expression_type="PYTHON",
                                code_block=codeblock)
... sort of retired...
DanPatterson
codeblock = """
        return 3
        return 9
    else:
        return
                                field=Category,
KatHoenke
Thank you!
