FeatureClassToFeatureClass_conversion works in IDLE but not as a tool
2542
09-27-2010 06:32 AM
deleted-user-rQoEFM5qzbHE
I was attempting to export a joined table to a new shapefile. I was successful in doing this through the IDLE debugger. However, when I try to do it as a tool in ArcToolbox, it crashes. I get an error message that says "A locator with this name does not exist".
I am not exactly sure what this error means in the context of exporting one feature class to another.
Thanks.
RDHarles
Without see your script, just guessing, but that error message USUALLY has to do with full paths (or lack thereof) to your input or output shapefile.
But it works if I run it from IDLE, that is what seems confusing. Even though I have set up inputs when running it as a tool, I commented out those sections and still have the paths hard coded in as if I was running it from IDLE.
RDHarles
Every environment (command line, IDLE, PythonWin, Toolbox) you run your script from is a little different (as far as coding goes). I don't run scripts from ArcToolBox, as it only complicates things, in my opinion.  I'm sure if you post your
script, the ArcToolBox experts on the board will take a look.
Alright, here is the code for my script. It is a bit messy at the moment...
# Import system modules
import sys, string, os, arcgisscripting
# Create the Geoprocessor object
gp = arcgisscripting.create(9.3)
# Load required toolboxes...
gp.AddToolbox("C:/Program Files (x86)/ArcGIS/ArcToolbox/Toolboxes/Data Management Tools.tbx")
try:
    gp.OverWriteOutput = True
except:
    gp.AddMessage("Unable to set the OverWriteOutpu to 1")
# Script arguments...
##inTable = gp.GetParameterAsText(0)
##inFC = gp.GetParameterAsText(1)
##String = gp.GetParameterAsText(2)
##SchoolLevel = gp.GetParameterAsText(3)
##numSchools = gp.GetParameter(4)
###gp.SetParameterAsText(5,"PS_lyr")
##SchoolLevel = "[" + SchoolLevel + "]"
inTable = "D:/ORED PROJECTS/GAMS to ArcMap/ES_05_UNROUNDED.csv"
inFC = "D:/ORED PROJECTS/GAMS to ArcMap/ScenarioTemplate_1011.shp"
String = "ES_06"
SchoolLevel = "[ES_0910]"
numSchools = 11
fieldsListFC = gp.ListFields(inFC)
#theFields = gp.ListFields(inFC)
# Process: Add Field...
gp.AddField_management(inFC, String, "TEXT", "", "", "30", "", "NON_NULLABLE", "NON_REQUIRED", "")
descTable = gp.Describe(inTable)
FullTName = descTable.CatalogPath
theTPath = (os.path.split(FullTName)[0])
theTName = (os.path.split(FullTName)[1])
descFC = gp.Describe(inFC)
FullFCName = descFC.CatalogPath
FullFCNameOut = FullFCName.replace(".shp", "_copy.shp")
theFCPath = (os.path.split(FullFCName)[0])
theFCName = (os.path.split(FullFCName)[1])
outFC = theFCName.replace(".shp", "_copy.shp")
gp.TableToDbase_conversion(inTable,theTPath)
outTable = inTable.replace("csv", "dbf")
# Process: Calculate Field...
gp.CalculateField_management(inFC, String, SchoolLevel, "VB", "")
gp.MakeFeatureLayer_management(inFC, "PS_lyr", "#", "#", "#")
gp.AddJoin_management("PS_lyr", "segment", outTable, "SEG", "KEEP_ALL")
gp.FeatureClassToFeatureClass_conversion("PS_lyr", theFCPath, outFC)
def zeros(*shape):
    if len(shape) == 0:
        return 0
    car = shape[0]
    cdr = shape[1:]
    return [zeros(*cdr) for i in range(car)]
# Determine the number of fields in the database after the GAMS
# output has been joined to the Scenario Template shapefile
theJoinFields = gp.ListFields(FullFCNameOut)
theTableFields = gp.ListFields(outTable)
lengthFC = len(theFields)
##lengthTable = len(fieldsListTable)
lengthJoin = len(theJoinFields)
fieldsJoin = zeros(lengthJoin,1)
# Create an array to hold the planning segment values for each
# of the schools
Elem = zeros(numSchools,1)
for i in range(0,numSchools):
    Elem = theTableFields[i + 2].name.encode('ASCII')
schools = zeros(numSchools,1)
M = zeros(numSchools,2)
rows = gp.UpdateCursor(outFC)
row = rows.next()
try:
    while row:
            schools = row.GetValue(Elem)
            M[1] = schools
            M[0] = Elem
        M.sort(lambda x, y: cmp(x[1], y[1]))
        M.reverse()
        if "SEG" > 0:
            school = M[0][0]
            row.SetValue(String, M[0][0])
        gp.AddMessage("You made it through the if statement")
        rows.UpdateRow(row)
        row = rows.next()
except:
    gp.AddError("Failed to set the value of new scenario field to new school assignment")
    #gp.deletefield(FullFCNameOut, theFields[lengthFC + 1 + i])
    gp.DeleteField_management(FullFCNameOut, "ES_05_UNRO; ES_05_UN_1")
##for i in range(0,numSchools):
##    gp.AddJoin_management("PS_lyr", String, inTable2, "NAME", "KEEP_ALL")
##    if "NAME" <> "NULL":
##        gp.CalculateField_management("PS_lyr", String, "NAME", "VB", "")
##gp.RemoveJoin(inFC, inTABLE2)
##gp.FeatureToPolygon("PS_lyr", inFC, "ATTRIBUTES", "")
del gp
The reason for setting this up as a tool, is that it is for some co-workers. They will be using this many times a year and will have different inputs each time.
Thanks.
