Feature to raster conversion ??? created raster do not line up (match) with shapefile
788
06-12-2011 09:55 AM
__7
Hi!
I used function Conversion tolls/Feature to raster to convert roads from shapefile to raster.
Any suggestion why Arcgis 10 made such a result, that shapefile and raster do not match positionally. Created raster should overlay roads positionally, but that didn`t happen.
Is there enything wrong with my Environments settings?
Here is picture attached.
MelitaKennedy
Esri Notable Contributor
Hi!
(As a colleague pointed out, when bringing my attention to your post) It looks like a datum / geographic coordinate system difference. I would expect that Feature to Raster should use the same coordinate system for the output that the input has, but are you overriding the output coordinate system in the geoprocessing environment settings?
What are the coordinate systems for the two datasets?
Melita
