Failed to create raster dataset
23239
11
07-19-2013 01:35 PM
CharlesCatson
Using ArcMap 10.1 in XPsp3. I can't rectify a georeferenced image. The procedure returns the erorr: "Failed to save raster dataset". Occurs when trying to generate a .tif or any of the compressed formats.
ShikoNjuno
Thanks @ Shiko!
All my raster datasets start with a year as in 1990xxxx. You mentinoned "...name is invalid...." and that was it, renaming into b1990xxxx solved my problem.
Interesting fix!!...glad that worked for you.
Cheers
Gisbert61
I find more situations (modelbuilder, python script, etc) where a filename starting with a number doesn't work but starting with a character does. No problem but took a while to figure it out.
