Using ArcMap 10.1 in XPsp3. I can't rectify a georeferenced image. The procedure returns the erorr: "Failed to save raster dataset". Occurs when trying to generate a .tif or any of the compressed formats.
All my raster datasets start with a year as in 1990xxxx. You mentinoned "...name is invalid...." and that was it, renaming into b1990xxxx solved my problem.
Interesting fix!!...glad that worked for you. Cheers
I find more situations (modelbuilder, python script, etc) where a filename starting with a number doesn't work but starting with a character does. No problem but took a while to figure it out.
