Exporting/Using layers generated by Network Analyst tools
1065
06-21-2011 07:23 AM
by Anonymous User
Not applicable
Original User: KevinCRDA
My model is creating service areas for retails stores. After these services areas are created, I want to project the polygon layer to make other manipulation on it, but I can't link directly the layer generated after the 'Solve' (Services Areas layer) and the project tool. I tryed the Copy Features too but it doesn't work, when I run the model it doesn't wait for the service areas to be created and give me an error that the Services Areas\Polygons doesn't exist.
Any idea ?
Oh, and I have another question for my other model. I want to export the table of the routes generated by the Make Closest Facility tool. I tried to use the Copy Rows tool but it doesn't work: it gives me an error saying that the Closest facility layer\Routes doesn't exist and the model doesn't run at all.
How can I do this ?
StefanHaglund1
Hi Kevin,
Use the Select Data tool, found in Data Management/General toolset. That will let you keep working on any output from the Network Analyst solvers.
Cheers,
Nooski
