Exporting After Join
14676
14
01-20-2015 10:52 AM
KevinLaughlin
This is frustrating because this is something I've done a thousand times before. However, I have a feature class called Parcels and I'm joining it to an assessment table based on a common field called parcel number. In ArcMap, it works fine. When I export the table, or export a subset selection, the table columns are all <null> in the exported FC. It does the same thing when I create a layer based off of a selection. It exports field names, but not the data in them.
I've recently just upgraded to 10.3, so I'm not sure if this is a bug therefrom, or I'm just missing something.
SusanJones
Hi Kevin
sounds like the source is not a Geodatabase Table or recognised format.
It might be easiest if you import the table into a file geodatabase. The objectids will be added automatically.
Susan
SusanJones1
Hi Kevin
Please check the data type of the joining field in both the destination and source. It's possible that there is a difference - joining double with integer data types has done this for me in the past.
It's possible that one of the data input sources has changed.
Susan
KevinLaughlin
The data sources are both strings.
SusanJones1
Hi Kevin
Are these fields are both less than 100 characters?
Are both these fields indexed?
Susan
KevinLaughlin
They are not indexed and they're fields that were in existence prior to my use of them, so I'll have to double check on their length.
The feature class is a general parcel feature class, it has owner name and a parcel ID number. The table is one that I had to convert from a text file (that was the format in which I downloaded it). Whether I have imported it into Excel, Access, or a Geodatabase it has acted similarly.
KevinLaughlin
The length of the feature class is set to 20. The length in the table is 255.
I imported the table from various formats, so could that field length be causing the issue?
SusanJones
Hi Kevin
255 text length is a default when features have been imported from non ArcGIS Formats like excel.
It's possible there are trailing spaces which is not being matched to the feature class.
Perhaps try trimming the field on both sides
Problem sounds like it is on the Table side.
Susan
KevinLaughlin
I had to leave the issue and I'm just now coming back to it.
The fields are similar in type (string), are not indexed, and have different 'precisisons' (I don't think that's a word).
As I mentioned in a response above, the table was downloaded as a text file and I've used different methods (Excel, Access, into the Geodatabase itself) to import it into ArcMap getting similar results each time.
KevinLaughlin
I meant field length. My bad.
I tried the join field tool and it gave me a similar result.
We don't have an option of an earlier 10.x machine. We're a small shop (two users) and we just upgraded everyone to 10.3.
A thousand may have been an exaggeration, but I would say I've done it quite a bit. When I was involved in the County I work for's parcel publication process this is how we published our parcels on a monthly basis - joined based off of parcel ID, and exported the join to get the final product. I do not remember it being this difficult before.
Tech support is an option, I just started here to see if 1) Anyone else had had this problem or 2) Maybe I could avoid tech support.
Kevin
KevinLaughlin
I tried to run it with the join tool. It threw and error saying the Assessment Table lacked OIDs (as it was a conversion from a text file, this isn't out of left field). So I was able to export the table to a table that had and OID field. I then attempted to perform the join in ArcMap the usual way (right-click --> join, etc) and it works in ArcMap. I then exported the file and had the same issue, the newly joined data shows up a <null> values in the exported copy. The fields are there, but the data is not.
After this, I attempted to use the Join Field tool again. This time it threw a '999999' Error which means there's an error but the code can't tell me what's happening.
I'm going to try another office to see if they have similar issues (there is one that hasn't upgraded to 10.3 as of yet). If they can perform the join-export than I'm going to lean toward an upgrade issue. But, I'm still eliminating causes at this point.
