Export values of rasters without attribute table
4780
9
11-28-2020 04:35 AM
CamiSunley
Hello, everyone !
I have a file with multiple rasters (stretched - without attribute table - but with only one value e.g. min value = max value) and I am trying to export each raster's value in a table/xls file where the values from all the rasters will have been registered (in a column for example) using model builder or arcpy.
Any suggestion is welcomed, thank you !
2 Solutions
DavidPike
MVP Notable Contributor
How many rasters have you got? You're saying each raster is made of cells entirely of one value?
Can you post a picture of this?
raster_object = arcpy.Raster(r'C:\MyStuff\Geo\Raster1.tif)
min_value = raster_object.minimum
max_value = raster_object.maximum
DanPatterson
MVP Esteemed Contributor
import arcpy
import numpy as np
arcpy.env.workspace = "c:/data/DEMS"  # --- Set the current workspace
rasters = arcpy.ListRasters("*")
out = []
for raster in rasters:
    inRas = arcpy.Raster(raster)
    arr = arcpy.RasterToNumPyArray(inRas)
    ras_min = np.min(arr)
    out.append([raster, ras_min])
print(out)
# ---- for now, just print it or see
# NumPyArrayToTable
Now, if you have nodata values to account for, then the code will have to be edited, or if the rasters are all over the place, then good luck.
This should give you an idea... but I never tested it, just cobbled together from the help files
NumPyArrayToTable—ArcGIS Pro | Documentation
... sort of retired...
DavidPike
CamiSunley
I have 1176 rasters. Yes, each raster is made of cells entirely of one value.
DavidPike
try the above script on one of the rasters.  If that works, it can easily be put into a for loop to iterate over the 1000.  Unsure if it's the fastest way if you're looking to do this regularly? Maybe @DanPatterson has a numpy method.
CamiSunley
Thank you, I' ll try it.. Should I add an 'export' expression after your script so as to save the value in a new table/array ?
DavidPike
for the moment just use
print(min_value)
Amadeus111
You can read min values from the each raster and add to a list, then write into an excel file. You might need to download xlswriter library or write into .dbf file and convert to excel file. There are multiple ways writing from list to excel file
import arcpy
import os
import xlsxwriter
raster_list = os.listdir(path/to/rasterfolder)
value_list = []
for each_raster in raster_list:
result = arcpy.GetRasterProperties_management(each_raster, "MINIMUM")
min_value = result.getOutput(0)
value_list.add(min_value)
with xlsxwriter.Workbook('RasterValues.xlsx') as workbook:
worksheet = workbook.add_worksheet()
for row_num, data in enumerate(value_list):
worksheet.write_row(row_num, 0, data)
CamiSunley
Thank you, I tried to install xlsxwrite with several ways but "invalid syntax" message is always appeared..
DanPatterson
import arcpy
import numpy as np
out = []
print(out)
# NumPyArrayToTable
CamiSunley
Thank you, I replaced 'min' with 'max' and it returned the right values, because when I run it for 'min' it returned numbers tending to zero.
