Export Training Data For Deep Learning
1597
04-09-2025 11:03 AM
NawarajShrestha
I am not able to use input classified raster while exporting data for deep learning. It says "however, the input can also be a point feature class without a class value field or an integer raster without class information." But when i use integer raster, its shows an error sign saying the raster is not thematic. has anyone used classified raster as n input raster for exporting data?
ShivaniPathak
Hi, for classified raster parameter the raster should be in thematic source type. You can change the source type of the raster using the following steps:
  • Open Catalog Pane.
  • Go to the location where you raster has been saved i.e. Database or Folder.
  • Select the raster and right click on it -> Click on Properties
  • In the Properties tab, Go to Source Type -> Select Thematic from the drop-down -> Click Ok
ShivaniPathak
