Export Multiple FCs
741
08-04-2011 11:04 AM
TedCronin
If I select a GDB, and select export multiple, to run the tool, when the tool opens up, I am seeing all my data in that GDB already in that tool.  I don't want arcmap to prepopulate.  Is this expected?
ChrisFox3
Yes, this is expected because you are launching the Feature Class to Geodatabase (multiple) from the context menu for the Geodatabase. If you want to launch the tool without any paramaters populated you can do this by accesing the tool from ArcToolbox or the Search Results.
