Export attribute table in .txt format using Model Builder
874
05-06-2014 08:08 AM
by Anonymous User
Not applicable
Hi all,
I would need to find out how to export an attribute table in .txt format using Model Builder.
markdenil
Export Feature Attribute to ASCII (Spatial Statistics)
Exports feature class coordinates and attribute values to a space, comma, or semi-colon delimited ASCII text file
If this tool is part of a custom model tool, the output text file will only appear in the Results window if it is set as a model parameter prior to running the tool.
markdenil
