error in fieldmapping/merge example?
918
04-28-2012 07:30 AM
JamesPrieger
I've been trying for hours to get the code in "Merge example 2 (stand-alone script)" on the "Merge (Data Management)" help file page(http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//001700000055000000) to run, and finally realized that there appears to be an error in this ESRI-provided script.
In the line:
fieldMappings.RemoveFieldMap(fieldMappings.FindFieldMapIndex(field.name))
The words "Remove" and "Find" should not be capitalized.  That is, the correct method names are "removeFieldMap" and "findFieldMapIndex", so the correct line is:
fieldMappings.removeFieldMap(fieldMappings.findFieldMapIndex(field.name))
Can someone from ESRI confirm/correct the help file? (or let me know why I'm wrong)
This is for ArcGIS 10. Thanks.
DanLee
by Esri Regular Contributor
You are correct. We will have the online help updated soon.
Thanks for the catch.
