Error 999999: Feature Compare Tool Please Help
2002
08-27-2014 01:34 PM
JenniferDick
I'm running the feature compare tool against 2 point layers.
In the feature compare tool one of the input fields is in regards to 'continue comparison': I set it to Continue_Compare to run in order to check other properties after encountering the first mismatch.
However, every time I set this input, and run the tool is runs for >30 mins and I get the noted error.
I've attached the Results file for reference. When I uncheck this input the tool runs smoothly and only takes <2 mins, without error.
Please help!
Jennifer
DanPatterson_Retired
What...if any ... other options did you use?
JenniferDick
Hi Dan,
If you open up the results file I attached It'll show you all the inputs I put into the tool.
Or else I can copy and paste them into another response for you?
Saw it...I will let the SDE people weigh in...don't use it, so it may be specific to it
JenniferDick
Okay thanks for looking
