doc for getValue and setValue
1159
11-26-2009 10:18 AM
TedCronin
http://help.esri.com/en/arcgisdesktop/9.4/help/index.htm#/Accessing-data-using-cursors/002Z0000001Q0...
For the getValue and setValue section
Sample script:
Snippet before the second for loop
# Open insert cursor on new lookup table
   tabcur = arcpy.InsertCursor(aenv.workspace + os.sep + tab)
   # Open search cursor on feature class
   featcur = arcpy.SearchCursor(env.workspace + os.sep + fc)
The text in bold should be env.
JeffMoulds
Thanks Ted. I'll pass that on to the doc writer.
TedCronin
So, there is no need to post to support, which If I don't have to is a ok.
One of my biggest peeves, are mistakes in the code, and this is a simple fix, but prior to 94 there are lots of little mistakes, and it can get quite frustrating.
