Detecting mound boundaries
1014
03-25-2013 03:35 AM
FionaStapleton
Hello all,
Does anyone have a method for detecting mound boundaries?
I am working on bathymetry data which consists of mound features ~ 50 m high and average 200 m diameter. Some are rounded, many are elongate. The edges of the mounds are difficult to see on a shaded relief image, impeding the ability to place accurate zone boundaries.
The mound boundary could be defined as the point where the 6 degree slope contour begins. I would like to create a polygon at    this slope degree contour boundary; however the resulting 6 degree slope contour raster has many 6 degree contour points (see image). So perhaps a this information could be used in addition to peak heights I.E. create separate polygons around all contiguous areas between the 6 degree slope contour and the peak height.
[ATTACH=CONFIG]22925[/ATTACH]
Or if anyone has software allowing me to utilize (or test) an automated mound detection method that would be ideal.
Thank you,
Stapes
