Delete Intermediate Data in Model Builder removes layers from TOC!!?
3658
02-14-2011 05:27 PM
KevinMcManigal
I have a large model that clips, styles and collects a lot of layers into a GDB. After is runs (took me two weeks to fix after Arc 10 upgrade, thanx), I used to clean the Dump folder with the Delete Intermediate Data command from the drop-down. Was a snap, no-brainer in 9.3. But now it actually deletes layers from the TOC of my Master.mxd. This is insane! Do I have to re-add my layers after I run a model? That is no happening. I have lost months trying to make things go that worked just fine before. Seems like alot of folks are having isues with Arc 10. Oh well, one crisis at a time!
Thanks, Kevin
by Anonymous User
Not applicable
You can try activating an alternate data frame before you run the model.
