Creating shared vertices for all intersecting features
887
04-03-2012 05:06 AM
JoshuaSilvey
I'm trying to create coincident (shared) vertices for all intersecting features.  This could be line-to-line, line-to-polygon, or polygon-to-polygon.  We cannot build a Topology because it requires feature datasets, and I've tried using the Intersect tool.  Does anyone know of a process that can be used to create these all at once?
Josh
DanLee
by Esri Regular Contributor
Are you looking for coincident lines among all these features? Does Intersect tool with LINE output type give you what you need? Coincident lines will be duplicated in the output, I believe.
curtvprice
Josh, you may want to try the Integrate tool, if these features are all in a single feature class.
Topology of course give you more control, but Integrate may do what you need.
