Creating a new script tool with outside python packages
1531
05-13-2022 03:40 AM
MatthewLehane
Hello,
Is it possible to create a script tool to add to a toolbox with python packages not in the ArcPro interpreter? Such as geopandas?
Or Is it possible to link to an outside ArcPro python environment? I am using Arcpy, but also a few other packages that are not found within the ArcPro environment.
Luke_Pinner
MVP Regular Contributor
Create a clone of the default arcgispro-py3 environment, install the packages you want and then activate it
Work with Python environments - ArcGIS Pro | Documentation
MatthewLehane
And is it possible to use a custom toolbox on an ArcGIS Online web map? That would bring up a similar question on script functionality.
Luke_Pinner
What are you actually trying to do?
MatthewLehane
I am trying to use a toolbox for an ArcOnline web map with some features not available in arcpy.
I have multiple projects, but one is to use the Census Data API in a toolbox and add that as a custom toolbox for downloading data. I guess if I am able to locally host a web map that could solve the issue? (if that is even possible).
Luke_Pinner
You can interact with AGOL maps using the ArcGIS API for Python. The arcgis package is pre-installed in Pro's default arcgispro-py3 environment.
