Create Space Time Cube tool not working
5445
11
08-14-2018 10:34 AM
NasserSharareh1
When I click on the "Create Space Time Cube" tool, it doesn't open it. Although other tools like "Optimized Hot Spot Analysis" works fine. What might be the problem?
NasserSharareh1
All four numbers are within the range of -180 to 180 and -90 to 90 decimal degree. See attached.
Thanks.
DanPatterson_Retired
So they are NOT projected... use the Project tool
Project—Data Management toolbox | ArcGIS Desktop
you will know you have done the right thing since 'Project' makes a new file and you have to provide a the new name
