Create New Feature Classes based on an Attribute
4919
7
01-13-2011 08:28 AM
MatthewBoyle
Does anyone know of a way to export new feature classes based on an attribute?  For example, I have a contour layer and I want to export each unique value in the elevation field to it's own feature class.  Any ideas...?  Thanks!
FrankVignati
if you want to do this in a model you can use the feature class to feature class tool from the conversion tools/to geodatabase and put the select query in the expression, or just do it one at a time using the same tool
MatthewBoyle
Dan,
I downloaded and tested out your tool.  I'm trying to use it with a contour layer.  So for every unique elevation, I'd like to create a shapefile for that elevation.  When I run your tool, it seems to work for one elevation but all the other elevations are tagged with 'did not work'...any ideas on what I'm doing wrong...?
DanPatterson_Retired
I failed to mention that you should add a new text field and get a text representation of the elevation.  Floating point numbers aren't supported directly.  If that doesn't work, zip the shapefile and email it to me at Dan_Patterson AT carleton DOT ca and I will have a look
BruceHarold
Esri Frequent Contributor
Hi
You can do this with a model using iterators.  I attach an example working with contour features.
Regards
MatthewBoyle
Bruce,
What exactly do I need to change to your model in order to get my data to work?  I haven't used iterators before.  Some background info on my data:
Contour data is in shapefile format.  The 'Elevation' field is a double field type.  I'd like to have the resulting shapefiles put in a separate folder if possible.
Questions:
1) Does my data need to be in geodatabase format?
2) Do I need to change the workspace in the model?
Annisa_IndahSari
If you use in Model Builder, then it is better to convert your data into geodatabase file in order to better fit the application.
If you create Personal Geodatabase, then u can use it as a workspace. This is also a good way to make a model.
