Correcting splinters and gaps between polygons
2394
7
01-03-2018 03:04 PM
janehansen
Hi I have a featureclass that contains many polygons many of which have gaps and splinters between them.  My concern is that some of the polygons are very small and narrow, some smaller than a few of the gaps. How do I remove the gaps and splinters without collapsing the polygons.
Thanks Jane
DanPatterson_Retired
Jane, could you mark an answer correct so that people will know a solution was obtained.  Thanks
on a copy! of the file, try Integrate,
otherwise you are looking at topology....
You could also try doing a select by attribute to select the polygons, which presumably, have a small area, and buffer those slightly, prior to performing the above.  If the area method is selecting other polygons which are fine... skip the idea
janehansen
Thanks for your help, you always provide me with helpful solutions..
janehansen
Thanks Dan, I was able to incorporate your suggestions and have completed
the project.
Jane
Guess it wasn't mine
janehansen
It was yours I must have hit the wrong reply.\
Sorry,
I'll fix that...you were a big help. Confirmed what I was doing and more.
Madanbhurati
You could select polygons which are very small and narrow by using select by attribute based on its Area. After selection verify them if they are satisfying your criteria.
Finally use Eliminate GP Tool from Data management->Generalization to  merging them with neighboring polygons.
For gaps look for topology as suggested by Mr. Dan Patterson.
