Converting Polygon Z to Polygon
7123
12-30-2013 05:28 AM
PhilipMorrison
I need to convert a feature class with a polygon z geometry to a shapefile with a polygon geometry.  I would like to import the shapefile into a web-based application but it will not accept shapefiles with a polygon z geometry.  Is there some way, using ArcMap 10.1 with a basic license and no extensions (i.e. 3D analyst), to convert a polygon z geodatabase (or shapefile) to a polygon shapefile?
Thanks.
Phil
JakeSkinner
Esri Esteemed Contributor
Hi Philip,
You can do this running the Feature Class to Feature Class tool.  Before executing the tool, click on 'Environments' at the bottom > expand Z values > set 'Output has Z Values' to Disabled:
[ATTACH=CONFIG]30146[/ATTACH]
JakeSkinner
Hi Philip,
