converting from UTM to degrees, minutes, seconds
3064
04-19-2010 08:15 AM
JeremyTibbetts
I need advice and/or Python code that is able to convert from UTM to degrees minutes seconds. I have seached these forums and other websites but havent' found anything that helps...
please help!
Jeremy
CurtisRuck
Try the pyproj library.  It wraps around the proj4 library.  You will probably have to do some dynamic stuff prior to feeding it to proj like picking the right projection for your UTM Zone and spliting the coordinates into x/y values.
KimOllivier
Honored Contributor
You can define an output projection (and transform) for a cursor and write out projected coordinates.
# extent_xy.py
# add extents of parcels in NZMG to a NZTM dataset for backward compatibility
# update to use on the fly projection directly from NZTM layers
# see Werner Flacke's book and script example
# updated for 9.2
# Kim Ollivier 13 April 2007
# input NZTM coverage library, parcel and plabel coverages
# output csv files to load and join back to coverages using AML
# issues solved:
#               add spatial reference to SearchCursor
#               define a Geographic Transformation that works with a coverage
#               because coverages cannot define NZGD2000 use WGS84 definition
#               or the transform is ignored
import os,sys,glob,arcgisscripting
gp = arcgisscripting.create()
def parcel(tile) :
    print "Parcel",tile
    ws = "e:/lib/nztm/tile/t"+str(tile)+"/data"
    outfolder = "e:/lib/nztm/tile/t"+str(tile)+"/data"
    ds = ws + "/parcel"
    f1 = open(outfolder+"/e_parcel.txt","w")
    f1.write("par_id,eminx_nzmg,eminy_nzmg,emaxx_nzmg,emaxy_nzmg\n")
    gp.Workspace = ds
    print ds
    # this is a good on-the-fly switch for the searchcursor
    # srOut must be a com object, not a file ref or a factory code
    rows = gp.SearchCursor(ds+"/polygon",'"PAR_ID" > 0',srOut)
    n = 0
    rows.Reset()
    row = rows.Next()
    while row  :
        print >> f1,"%d,%s" % (row.par_id,row.shape.Extent.replace(" ",","))
        row = rows.Next()
        n +=1
    del rows
    print n,"Polygons"
    f1.close()
    return
def plabel(tile) :
    print "Plabel",tile
    ds = ws + "/plabel"
    f2 = open(outfolder+"/e_plabel.txt","w")
    f2.write("par_id,eminx_nzmg,eminy_nzmg\n")
    gp.Workspace = ds
    rows = gp.SearchCursor(ds+"/point",'"PAR_ID" > 0',srOut)
    n = 0
    rows.Reset()
    row = rows.Next()
    while row  :
        n += 1
        print >>f2,"%d,%s,%s" % (row.par_id,row.shape.Extent.split()[0],row.shape.Extent.split()[1])
        row = rows.Next()
    del rows
    print n,"plabels"
    f2.close()
    return
# ------ main ----
srOut = gp.CreateObject("SpatialReference")
srOut.CreateFromFile("c:/arcgis/nzmg.prj")
# WGS_1984 works for coverages defined with an equivalent custom Transverse projection definition
gp.GeographicTransformations = 'NZGD_1949_To_WGS_1984_3_NTv2' # ;New_Zealand_1949_To_NZGD_2000_3_NTv2'
# but is this being used?
inFC = "e:/lib/nztm/tile/t1009/data/plabel/point"
# not at 9.3?? outFC = "in_memory/dummy1.shp"
outFC = "c:/tmp/dummy1.shp"
outPrj = "c:/arcgis/nzmg.prj" # cannot be a COM object or factory id 43040
geoTrans = "NZGD_1949_To_WGS_1984_3_NTv2" # ;New_Zealand_1949_To_NZGD_2000_3_NTv2"
if gp.Exists("c:/tmp/dummy1.shp") :
    gp.Delete("c:/tmp/dummy1.shp")
gp.OverwriteOutput = 1
gp.MakeFeatureLayer_management(inFC,"tlayer","PLABEL# < 3")
gp.Project_management("tlayer",outFC,outPrj,geoTrans)
try :
    if sys.argv[1].upper() == 'ALL' :
        lstTile = range(1001,1013)
    else :
        lstTile = [ tile for t in sys.argv[1].split(",")]
except :
print "begin extent_xy"
for t in lstTile :
    print t
    parcel(t)
    plabel(t)
JeremyTibbetts
Thank you for your suggestions, I was able to make the conversion using pyproj. However, I am only able to run my code once, if I try to run the code once again, an error occurs (errors 999998). I have narrowed the problem down to the pyproj import, and I am wondering if I need to close pyproj at the end of the code to avoid a schema lock of some sort? Also, I'm using Proj in a function, do I need to close the function or cancel its returns to avoid a lock?
Thank you,
Jeremy
