Convert buffer polygons into polylines (using geometry of Street Centerlines)
3011
05-06-2022 01:46 PM
EMH_Cbus
I am trying to use Street Centerlines polyline segments as the geometry to convert a polygon feature class into a polyline feature class, while also transferring over an single attribute field (named "PROJECTID", type Double).
Unfortunately, even when multiple line segments exist "Completely Within" a given polygon, they still will not Merge (I even cleared out the Field Map section).
I am also not sure what tool to use to transfer the attribute value for my "PROJECTID" field of the old polygon feature into the field for the new polyline feature.
Thoughts?
RhettZufelt
MVP Notable Contributor
If I'm guessing correctly as to what you want, sounds like a spatial join on the two datasets will do it.
That will let you copy attributes from the polygons to a polyline layer that overlap them.
R_
RhettZufelt
R_
EMH_Cbus
That seems to work, and I had to also use Dissolve instead of Merge since I am combining features within the same feature class, not multiple feature class files.
  • Select by Location: Centerlines "Completely Within" Project Selection
  • Spatial Join: Clines_dissolved (Target), Project_Selection (Join Feature), 1 to 1, "Completely Within"
  • Append: Cline_Proj_Added (Input), Polyline_Polylines (Target), "No_Test" (Schema)
