Connect to SDE with arcpy
26670
08-13-2010 11:40 AM
ChrisMathers
All I can find in the help for connecting to an SDE with arcpy is how to make a SDE connection file. I already have one of those because the SDE is available in catalog (C:\Documents and Settings\cmathers\Application Data\ESRI\ArcCatalog\OSA@[email protected]). I just want to know how to read that file with arcpy and then read some data from the server. How do I connect to the SDE from python?
AndrewChapkowski
To list data from the server, you can do something like this:
import arcpy
from arcpy import env
env.overwriteOutput = True
env.workspace = r"C:\Documents and Settings\cmathers\Application Data\ESRI\ArcCatalog\OSA@[email protected]"
fcList = arcpy.ListFeatureClasses()
# Copy shapefiles to a file geodatabase
for fc in fcList:
    print fc
That's just one example of how you can use sde connection files.
If you wanted to reference a feature class, you could do something like this:
fc = r"C:\Documents and Settings\cmathers\Application Data\ESRI\ArcCatalog\OSA@[email protected]\<FeatureClassName>"
Hope this helps.
ChrisMathers
Thanks a lot. Using the sde file as the workspace is just what I needed to know!
