Concatenate string and variables in where clause?
2416
08-13-2010 11:11 AM
ducksunlimited
Dear All,
Can anybody correct the syntax error in the following codes? I use personal GDB. I knew the probelm is with the where clause, but don't know how to fix it. thanks,
uid = row.GetValue('UID')
state = row.GetValue('STATE')
gp.Select_analysis(USA_State, USA_State_Select, "UID <> " + str(uid) AND "STATE = " + state)
ChrisMathers
You need to build the string outside of the tool perameters so that you can wrap parts of it in quotes for the tool. Remember this isnt just a string, its and SQL statement so you have to comply with SQL conventions.
>>>where="UID <> \'" +str(uid) + "\' AND STATE = \'" +state +"\'"
"UID <> 'oid' AND STATE = 'state'"
gp.Select_analysis(USA_State, USA_State_Select, where)
ducksunlimited
thanks for the reply
because i use mdb, i changed your code to where="[UID] <> \'" +str(uid) + "\' AND [STATE] = \'" +state +"\'"
and returned the error:
An invalid SQL statement was used. [SELECT * FROM USA_STATE WHERE [UID] <> '1' AND [STATE] = 'IL']
to me, this is a correct SQL expression. but it appreared as an error.
any help?
thanks
RDHarles
Try this one (singles AND doubles around variables, brackets around PGDB's):
qry = "[UID] <> '"+uid+"' and [STATE] = '"+state+"'"
gp.Select_analysis(USA_State, USA_State_Select, qry)
BruceHarold
Esri Frequent Contributor
Hi
Don't forget that you can make your code workspace-portable by using the AddFieldDelimiters method to wrap field names, and Python's repr function to quote string literals in the SQL expression.
Something like:
uid =  row.getValue('uid')
state = row.getValue('state')
ws = gp.Describe(USA_State).path
gp.Select_analysis(USA_State, USA_State_Select, gp.AddFieldDelimiters(ws,'UID') + " <> " + repr(uid) AND " + gp.AddFieldDelimiters(ws,'STATE')  + " = " + repr(state))
Regards
