Clipping inside vs outside.
9544
11
10-17-2013 08:23 AM
ScottBarron
I have a large raster image, and a much smaller raster image located inside the larger one. I want to clip a hole in the larger one where the smaller image is. How do I do this? I came across the clip function: http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//009t00000048000000, which appears to be exactly what I want, but I can't seem to find the tool, even when I search for it... Any advice?
-Scott
RyanDeBruyn
Yes, those tools are cool...however, you may need the Spatial Analyst and a higher ArcGIS Desktop license to run any or all of the associated tools.
The requirements for the supplemental tools are:
ArcGIS 10.1 Service Pack 1 and Spatial Analyst Extension
Only the Filled Contours tool requires ArcGIS for Desktop Advanced or ArcGIS for Server Advanced and Spatial Analyst Extension.
RyanDeBruyn
Now we're talking! Thanks Steve, this looks great. Any advice on using the toolbox? I downloaded it, and change the python scripts per the txt file, but whenever I try to open a tool it says "Invalid Tool. Unable to execute the selected tool."
Scott what version of ArcGIS are you using?
Are you refering to changes in the ReleaseNotes.txt needed for the tools to work with 10.1 rather than 10.1 service pack 1 as required?
