Clip Polygon to raster extent
3616
09-15-2021 10:12 AM
jblng
Hi all,
I'm curious if anyone has been able to clip a polygon dataset using the extent of a raster dataset, using ArcPro? Or simply get the bbox of the raster without python. I'd much prefer to save time and not to convert the raster to polygon, as it is extremely large and high-res, but maybe this is a pipe dream.
Thanks!
David_Brooks
MVP Regular Contributor
@jblng not sure what extensions you have, but one approach is to reclassify your raster to be values of NODATA and 1 (or 0 and 1) etc and then run Polygon to Raster and just delete feature that isn't 1.
David
..Maps with no limits..
David_Brooks
David
jblng
Hi David, thanks so much. I'll give that a go. Reclass will probably quicken the raster to polygon process!
