Clip Outside
5170
9
07-02-2013 05:08 PM
by Anonymous User
Not applicable
Original User: z3444916_UNSW
Hi Guys,
Is anyone know how to clip outside. Because we interesting in finding the gap of area after the clippping process.
Normaly,
[ATTACH=CONFIG]25674[/ATTACH]
I want to get the result below,
[ATTACH=CONFIG]25675[/ATTACH]
Thank you for your attention.
Best Regards,
WF
DaleHoneycutt
Erase tool?
DanPatterson_Retired
symmetrical Difference if you have an Arc* advanced version
http://resources.arcgis.com/en/help/main/10.1/index.html#//00080000000r000000
by Anonymous User
Not applicable
Wow..Symmetrical Difference Tools is really work for my case.
Thank You.
Best Regards,
Wildan Firdaus
WildanFirdaus
From theory the Erase tools should more suitable for my case. But, it is not working, there is no result from Eraser tools.
Even though the Erase feature is generated from buffer process, which is mean an Area type.
[ATTACH=CONFIG]25676[/ATTACH]
Why the Erase tools is not working?
Anyone knows about this??
Best Regards,
Wildan Firdaus
I think the erase feature needs to be completely within the feature you are erasing from symmetrical difference doesn't
by Anonymous User
Not applicable
Original User: Youngy
use clip but select preserve the area that intersects rather than the default discard the area that intersects.
TuridBrox
I'm trying to do the same thing as the thread starter.
When editing I can use "Clip" and "Discard the area that intersects", but I've found no way of doing this using model builder.
Is it possible?
When using the Clip or Erase tools in Model builder I am always left with an output. I want to keep the original data, but clip a hole in them, not make a new feature class.
by Anonymous User
Not applicable
If you do not wish to output to an actual feature class I use 'in memory results' for a lot of my intermediate data plus it dramatically speeds up the process time. Take a look half way down the page at the following link;
http://resources.esri.com/help/9.3/arcgisengine/java/Gp_ToolRef/automating_your_work_with_models/int...
ot sure how to switch the clip selection in model builder though - bit annoying you don't get the same options.
TuridBrox
Thanks for the tip, I might use it in another project.
The problem here is that the clip tool doesn't remove anything from the original data set.
