Classify in attribute table
2777
10-18-2010 07:56 AM
MartinKadl_ák
I have this problem: I have a shapefile of the column in which data and I need to classify data into different columns in the boundaries of those intervals. Any ideas how to do it? thank you very much
DonovanCameron
So you want to have a new field with where it took the range of values from an existing field and reclassified them?
Ex,
Field1 ->  Field2
1 -> A
2             -> A
3             -> A
F1 ->  F2
4             -> B
7 ->             B
9 ->             B
MartinKadl_ák
I need to appear in a new column has reclass value from the original column (example:
f1                    f2
        156                                       1
        160                                       1
        300                                       3
        347                                       4
DonovanCameron
MartinKadl_ák
Yes, that's about it, namely that Python does not work, but through the VB always something do it, but it does not list the values that I enter there, but just the same 0,I think it will be in Expression, what exactly is it to write?
MartinKadl_ák
everything works as it should, thank you very much for your advice 🙂
