cannot use VB expressions for services
6025
11-06-2012 09:57 AM
KevinGooss
10.1 geoprocessing tool.
I'm getting an error during the analysis phase in ArcCatalog while trying to publish my gp service. It says I can't use VB expressions in the Calculate Field Tool. The severity is High but i am still able to publish.
Here is the only line in my py script that uses the CalculateField tool:
arcpy.CalculateField_management("in_memory/buffer", "GP_ID", "x", "PYTHON", "x = '" + uniqueid + "'")
Am i missing something? Because I don't think there is any VB in there.
AnthonyGiles
Honored Contributor
Kevin,
Using Server 9.3.1 you have to change the Expression Type parameter to 'PYTHON_9.3'. For the calculate field to work.
http://support.esri.com/en/knowledgebase/techarticles/detail/36571
Not sure if this is still the case with 10.1, but worth looking at
Regards
Anthony
KevinGooss
no dice. but thank you for the suggestion.
KevinHibma
Its not an error, just a high-warning.
Check the help here:
http://resources.arcgis.com/en/help/main/10.1/index.html#//005700000093000000
Specific to your case:
Solution
    If your tool is not using a VB expression, you can ignore this warning.
Per Anthony's response, the KB article still holds true...we now have the ability (in 10.1) to let you know about it and offer suggestions.
KevinGooss
Cool. Thank you.
AnthonyGiles
Honored Contributor
Kevin,
Not that I am an expert in python but looking at the help file for Calculate Field the syntax is:
CalculateField_management (in_table, field, expression, {expression_type}, {code_block})
so if uniqueid is a variable have you tried:
arcpy.CalculateField_management("in_memory/buffer", "GP_ID",uniqueid,"PYTHON")
or if uniqueid is a field name
arcpy.CalculateField_management("in_memory/buffer", "GP_ID", "!uniqueid!","PYTHON")
Regards
Anthony
