Can I load reports using ModelBuilder
2116
10-28-2015 09:24 AM
KarlKeough
Can use the Load Reports command in Modelbuilder or suing python?
DanPatterson_Retired
Basically if it is a tool in arctoolbox, then you should have access, here is the arctoolbox tree
If it isn't in the tree, then you can examine the arcpy classes and methods
