Calculating double in python results in integer, while AM calc'ing produces decimals
3323
07-26-2010 02:05 PM
JanicePoehlman
I'm running a calculation that produces decimals while using the AM field calculator but results in integers while using python.  Can you help?
The AM field calculator expression:
minutes = [length_mile] *60 / [speed_limit]
The python expression:
gp.calculatefield_management ("highway", "minutes", "!length_mile!*60/!minutes!","PYTHON")
The field to be calculated is added using gp.addfield_management:
gp.addfield_management (filename, "minutes", "double")
After my python code produced numbers rounded to the integer, I double-checked using the field calculator and the result included the decimals.  I need the decimals.
Can anyone help with my programming oversight?
Thank you.
Janice Poehlman
Wisconsin DNR
ChrisSnyder
Honored Contributor
Python is kinda weird with division, and will return an integer anytime all the inputs are integer (example: 3/2 = 1). The trick is to just force one of the variables to be a decimal (aka float). (example: 3/float(2) = 1.5). Try this:
gp.calculatefield_management ("highway", "minutes", "!length_mile!*float(60)/!minutes!","PYTHON")
DanPatterson_Retired
or more simply, put 60.0 in the line to enforce floating point division
JanicePoehlman
Great, thank you Chris and Dan for your replies and solutions.
Janice Poehlman
Wisconsin DNR
P.s. the application is drive-time analysis for recreation land profiles and guidance for funding priorities.
