Calculating Distances Between Different Layers
1536
07-16-2010 09:22 AM
JustinShelton
I am not sure if this is the right place to post this, but I'll go ahead and explain my situation. I have two feature classes, both are polygons. One layer is blockgroups for Mobile County, Alabama, the other is a layer for hospitals throughout the county. I want to measure the distance from each block group to each hospital, such that it creates new fields in the attribute table for the distance to each hospital. I want an output that results in each block group having new fields for their distances to each hospital in Miles. Is there anyway to do this other than manually measuring???
ChrisSnyder
Honored Contributor
Take a look at the Near tool: http://webhelp.esri.com/arcgisdesktop/9.3/index.cfm?id=1352&pid=1347&topicname=Near_(Analysis)
You must have an ArcInfo license to run it however...
JustinShelton
Thanks for the reply, but the "Near" process only gives distances in values of -1 or 0. I need something that returns a value of distance in miles.
ChrisSnyder
Honored Contributor
Is your data in a geographic projection? If so, you may need to project it into something like stateplane or UTM...
JustinShelton
The data is in state plane (feet). However, it still gives me figures of -1 and 0, an all or nothing sort of thing. I need actual distances in feet.
BBicking1
Justin,
there is currently no tool that returns actual distance measures.
Use http://ideas.arcgis.com/ to request that the Near tool be enhanced with this option. I confirmed it's technically possible.
Barbara Bicking
ESRI - Geoprocessing Team
