calculateing fields with python script
1000
04-14-2010 06:29 AM
JeremyTibbetts
Hello, I have a script that reads a line, divides the line based on a values from a text file, and creates point features at the divisions. Now what I want to do is add fields and calculate the fields are the points are being created. But i'm not sure how it would be done.
I was thinking of creating a function, with the multiple calculate field statements in it, and then call the function as the points are being created.... below is my code..
#Import native arcgisscripting module
import arcgisscripting, os
# Create the geoprocessor object
gp = arcgisscripting.create(9.3)
pnt = gp.CreateObject("Point")
gp.workspace = "H:\Nova Scotia Geomatics Centre Project\Index_Photos.gdb"
Rollnumber = gp.GetParameter(0)
Flightline = gp.GetParameter(1)
Denom_Table = gp.GetParameterAsText(2)
SourceData = gp.GetParameterAsText(3)
OutSource = gp.GetParameterAsText(4)
Photocentre_Start = gp.GetParameter(5)
int(Photocentre_Start)
print "This is the photocentre startpoint" + Photocentre_Start
# Load required toolboxes
gp.AddToolbox("C:/Program Files/ArcGIS/ArcToolbox/Toolboxes/Data Management Tools.tbx")
# Local variables
Photocentres_Flightline_ = "H:\\Nova Scotia Geomatics Centre Project\\Index_Photos.gdb\\Photocentres_Flightline_"
Index_Photos_gdb = "H:\\Nova Scotia Geomatics Centre Project\\Index_Photos.gdb"
# Process: Create Feature Class
gp.CreateFeatureclass_management(Index_Photos_gdb, ("Photocentres_Flightline_" + Rollnumber + "_" + Flightline), "POINT", "", "DISABLED", "DISABLED", "", "", "0", "0", "0")
# Add Fields
gp.AddField_management((OutSource + Rollnumber + "_" + Flightline), "DLCODE", "SHORT", "", "", "", "", "NULLABLE", "NON_REQUIRED", "")
gp.AddField_management((OutSource + Rollnumber + "_" + Flightline), "PhotoID", "SHORT", "", "", "", "", "NULLABLE", "NON_REQUIRED", "")[/SIZE]
... There are many more fields but left them out for simplicity...
# Indentify the geometry field
desc = gp.Describe(SourceData)
shapefieldname = desc.ShapeFieldName
# Create search cursor and insert cursor
inrows = gp.SearchCursor(SourceData)
inrow = inrows.next()
outrows = gp.InsertCursor(OutSource + Rollnumber + "_" + Flightline)
# Assign the denominator table to the varible infile1
infile1 = Denom_Table
#check if the file exists
#if it does not exist, a print statement that tells the user
if os.path.exists(infile1) is True:
    infile = open(infile1, "r")
    #print "Demoninators for flightline  + outfc")
else:
    print "The file was not found"
# While loop for each feature
while inrow:
    # Create the geometry object 'feat'
    features = inrow.GetValue(shapefieldname)
    # Create a variable called feature class, based on the feature class which contains the line segements
    featureclass = (SourceData)
    #print "Feature " + str(inrow.getvalue(desc.OIDFieldName)) + ":"
    #Collect the coordinate for a feature
    #Assign the coordinate to a variable
    x1 = inrow.Shape.FirstPoint.X
    y1 = inrow.Shape.FirstPoint.Y
    x2 = inrow.Shape.LastPoint.X
    y2 = inrow.Shape.LastPoint.Y
    #print "first coordinate is:", x1 ,",", y1
    #print "second coordinate is:", x2 ,",", y2
    # The user inputs what the line should be divided by
    # This number is assigned to the variable den (denominator)
    # Den, then has to be converted to an integer.
    current_record = infile.readline()
    den = int(current_record)
    # Based on input, the equation used to find new coordinates will differ
    if den == 2:
        # If user inputs 2, this formula is used
        x3 = (x2 + x1) / 2
        y3 = (y2 + y1) / 2
        #print "new photocentre's coordinates are:", x3, ",",  y3
        # Use coordinates to create a point feature
        pnt.X = x1
        pnt.Y = y1
        # Insert the point feature into the feature class
        inrow = outrows.NewRow()
        inrow.shape = pnt
        outrows.InsertRow(inrow)
        outrows.NewRow
        I would like to have a function be called here, after the point has been created to populate the previously added fields with values.
        # Use coordinates to create a point feature in the feature class
        pnt.X = x3
        pnt.Y = y3
        inrow.shape = pnt
        outrows.NewRow
         Same here.. and so on
    elif den == 3:
        # If user inputs 3, this formula is used
        x3 = x1 + ((x2 - x1) / 3)
        y3 = y1 + ((y2 - y1) / 3)
        x4 = x1 + ((x2 - x1) / 3)*2
        y4 = y1 + ((y2 - y1) / 3)*2
        #print "new photocentre's coordinates are:", x4, ",", y4
        pnt.X = x1
        pnt.Y = y1
        inrow.shape = pnt
        outrows.NewRow
        pnt.X = x3
        pnt.Y = y3
        inrow.shape = pnt
        outrows.NewRow
        pnt.X = x4
        pnt.Y = y4
        inrow.shape = pnt
        outrows.NewRow
    else:
        # If the user inputs anything other than 2 or 3 (ei. 1), this means no division is needed
        pnt.X = x1
        pnt.Y = y1
        inrow.shape = pnt
        outrows.NewRow
        #print "No Division Necessary"
pnt.X = x2
pnt.Y = y2
inrow.shape = pnt
#outrows.NewRow
infile.close()
del inrows
I'm relatively new to python, and i'm not sure exactly how to write the function i'd like to create or even if its the best way to calculate the fields as the point is being created..
Please help me out thanks!!
BradPosthumus
Since you're already using an insert cursor and creating new rows, you just need to set the attribute values of each new row before inserting it into the table. So you can change this:
inrow.shape = pnt
outrows.NewRow
...to this:
inrow.shape = pnt
inrow.SetValue("DLCODE", <DLCODE value>)
inrow.SetValue("PhotoID", <PhotoID value>)
#outrows.NewRow - no need for this line
Since this code repeats itself in your script, you could instead define it within a function (as you mentioned).
def addNewRow(outrows, pnt, dlcodeValue, photoIdValue):
[INDENT][INDENT]inrow = outrows.NewRow()
inrow.shape = pnt
inrow.SetValue("DLCODE", dlcodeValue)
inrow.SetValue("PhotoID", photoIdValue)
outrows.InsertRow(inrow)[/INDENT][/INDENT]
Drop this at the top of your code, and then call it like this:
pnt.X = x1
pnt.Y = y1
addNewRow(outrows, pnt, <DLCODE value>, <PhotoID value>)
pnt.X = x3
pnt.Y = y3
Also, don't forget to delete your outrows variable at the end of the script (del outrows). Just in case.
Brad Posthumus
