Calculate Geometry Crashes ArcMap
1431
12-18-2012 03:48 AM
ColleenLemasters
Every time I try to use the Calculate Geometry tool in the attribute table to calculate the X and Y for the center of polygons it crashes ArcMap. Does anybody else have this problem, and what have you done to fix it? I use it all the time on points and even polylines and it works just fine, but for some reason it doesn't like polygons, and I'm running v10.
JakeSkinner
Esri Esteemed Contributor
Hi Colleen,
1.  Does this occur for all polygon feature classes, or just one in particular?
2.  Do you have any service packs installed?  I would recommend installing SP5 if you haven't already.
ColleenLemasters
So far it has done it on all polygons that I have tried. I'm not sure if I have SP5 or not. I'm supposed to be upgradeing to 10.1 soon, but I just haven't had the time to do it yet. Thanks for your help!
MatthewPayne
Colleen,
I tested on a v10 SP5 machine and successfully Calculated Geometry for the X and Y coordinates of the centroid with a polygon feature class.  There seems to be something going on with either a) your data or b) your current mapping system.  You may try to:
1) Use the Feature Class to Feature Class tool to make a copy from your polygon layer (to relieve potential corruption within the file)
2) Upgrade to SP5 (you can check which SP you have in ArcMap by going to Help > About ArcMap)
Other things to consider are:
1) What field type are your x and y fields?
2) Where is your data located? (move it local if it is on a network or shared drive and then test it)
3) Are you working in a specific saved MXD file? (open a blank, fresh instance of ArcMap, drag in your one polygon layer, and test the performance, to relieve MXD corruption)
Hope this helps!
Matt Payne
