Bypass output value of Iterate Field Values in Model Builder
846
03-20-2014 08:24 AM
JustinFuto
I have a model that I'm using to iterate through a parcel feature class, gather all the values of 'parcel id',then using the collect values tool to collect all the fields.  From this process I need to run my python script that requires 'parcel id' input to run.  When I open the script in model builder I am only given the option to select the 'Value' from the iteration that only contains the last parcel selected.  How can I bypass that selection and use the 'Stored Values' (which contains all of the parcels selected from the Iterate Field Values tool?
Thanks in advance
