Buffering by percentage instead of distance?
6704
10
05-07-2021 06:31 AM
dlj19220301
Pretty simple question. I have a shapefile of different-sized polygons, but I don't want to buffer them by a uniform distance. I want to reverse buffer them by a percentage. An example would be buffering each polygon by -50%.
I don't know if this is already a built-in option. Or do I need to calculate a field in my attribute table with this value, and then set the buffer option to "field" instead of by "distance"?
Thoughts?
KateDoughty1
Not sure if this is still relevant or open but in ArcGIS Pro 3.2, you can buffer by a field. Divide the area percentage by perimeter length and us that field to calculate your desired linear buffers.
