Attaching a field to a image name
918
10-28-2021 06:33 AM
SLouq
by MVP Alum
Hi all,
I have a table of images from a shared hosted feature service which I was able to extract to a folder locally through a script available online. However, this script just extracted the images with the image title
ie. image0-20210902-154626 and so forth
I also have a related point feature class for this table where each point has an image attached to it. What I would like to do is extract the images but use a field in the feature class as a name for each image instead of
image0-20210902-154626 or
field name + image0-20210902-154626
Is there a way to do this?
DuncanHornby
MVP Notable Contributor
Did you actually mean for 1 field (lets call it ImgName for example) you want to store the image name for its point, so names are stored in rows, a spoofed example below?
ObjectIDShapeImgName
1pointimage0-20210902-154626
2pointimage0-20210902-154627
3pointimage0-20210902-154628
Do your points already exist or do they need creating? If they exist what is their relationship with the image, are they centroids for example?
SLouq
by MVP Alum
Thank you for your reply.
I was able to use the Join and Relates tool to join my point feature table to the attachments table, then I was able to copy the field to my attachment table. This allowed me to modify that script to extract the field I needed along with the attachments. Mission accomplished!
