Area inside of a polygon
1303
11-28-2010 06:22 AM
JoshuaStiller
Hello.  I am new to GIS, and could use some advice.
I have a polygon layer with 5km^2 breeding bird blocks.  I'm trying to find the area of different landcover types inside each block.  I have lumped the NLCD data into 4 separate raster files (1 for wetlands, ag land, urban/residential, and open water).  I can easily convert the breeding bird vector file into a raster if that makes it easier.  I'm just lost on how to get the area of these 4 landcover types in each block!
Any suggestions? Thanks!
NiklasNorrthon
Store your vector data in a file geodatabase, and there will be a field in the attribute table for the shape area, which is automagically calculated for you.
To get that value in a script you need a cursor object. Search for that in the desktop help for sample code.
ChrisSnyder
Honored Contributor
If you go the all raster route, the Spatial Analyst Combine tool is what you will need (it's the raster equivalent of a vector "intersect" operation).
