Hi Folks,
Quick question, what is the proper format to enable Z and M values when using the arcpy.polyline command? The help menu says the default is 'False', which implies that the enabling value is "True", but it does not seem to work (I also have the arcpy.env settings Z and M enabled). I have also tried "hasZ" and "hasM" as well as "Enabled." Nothing seems to work.
polyline = arcpy.Polyline(array, projection, "True", "True")
I would appreciate any feedback.
Best,
Erich
