ArcPro2.1 Apply Symbology From Layer tool error: arguement "Update Symbology Ranges by Data" not working
4967
14
03-22-2018 04:20 PM
erinheinrich
Hi all,
Think I've found a bug
To my understanding this arguement should recalculate my quantiles based on the new data, but it just uses the same classes from the source Symbology Layer.
Here are my inputs:
Once I've run the tool as per above, here are results:
Note, exactly the same break points... not what it is supposed to do... which is"
Anyone got ideas? Thanks.
KoryKramer
Esri Community Moderator
I apologize that you're experiencing this issue.
I tested this workflow and to me it appears to be a bug that the ranges don't update.  I've logged [BUG-000115732: Update Symbology Ranges by Data does not have any effect when using Apply Symbology From Layer with raster data.]  If you're experiencing this issue, please call technical support to verify and get attached to the bug for tracking purposes.
Thank you.
MichaelVolz
Esteemed Contributor
Kory:
The OP says this is a problem in Pro 2.1.  When you replicated the issue to say it was a bug, did you perform your testing in 2.1 or the most current version 2.2.0?
KoryKramer
I tested in 2.2 and see the same behavior.
EricErtl
I have been experiencing the same behavior but with vector data.  I will log with tech support as well.
KoryKramer
Thanks, Eric.  Once you and an analyst have confirmed you're seeing this same issue, they would be able to attach you to the bug referenced above in the thread: BUG-000115732
Cheers
