ArcMap Dem to Raster cutting off Data
1881
01-08-2020 04:04 AM
ElizabethFarrell
I have a floating point USGS DEM that I am putting through the ArcMap DEM to Raster tool. The output consistently cuts off a portion of the input (see below). Any thoughts as to why?
Tags (3)
SteveLynch
Rather use the CopyRaster tool if you want it in another format. It should also be noted that the USGS DEM is a valid raster dataset and can be used without being converted.
DEMToRaster has been deprecated in ArcGIS Pro 2.5
-Steve
SteveLynch
-Steve
ElizabethFarrell
Thank you, CopyRaster is a new tool for me, but it accomplished what I needed it to!
