Aggregate Polygon tool  - Defect - Polygon with exclusion ring
1520
07-11-2013 09:37 AM
LakshmananVenkatesan
We use geoprocessing service in our application and one of the tool we are using is Aggregate Polygon tool in Cartography. This tool is being used to union two or more geometries which are at a particular distance from each other and these geometries can contain exclusions(inner ring).   But the issue we are facing is if the exclusion polygon(inner ring) contains 3 vertices, then Aggregate Polygon is removing the exclusion polygon. We tried with so many parameters and even tried with giving some values in Minimum_Hole_Size but no success. Any help would be very much appreciated.  Please find attached document which explains the issue using ArcMap.  Please let me know if you need more information.
SR
DanLee
by Esri Regular Contributor
Have you tried to project your data and then use Aggregate Polygons?
ESRI Agreed this as a defect in 10.0. Bug #NIM093472  Aggregate Polygons tool eliminates interior holes that consist of only three vertices.
