Adding a sring value to a field with python
1397
06-29-2010 12:10 PM
HolmSeifert
Hi everyone,
i want to assign a variable , a string, to a field. Therefore i have created with python a field and want now assigning a value to this field,
But i get only this failure message back.
<class 'arcgisscripting.ExecuteError'>: ERROR 000539: Error running expression: name2 <type 'exceptions.NameError'>: name 'name2' is not defined
Failed to execute (CalculateField).
The python code is listed above.
for raster in rasterlist:
    name = str(raster) + "_WGS84"
    name2 = str(raster) + "test"
    gp.MosaicToNewRaster_management (raster, OutputLocation, name, coordinatesystem, pixeltype, cellsize, bandnumber, "", "")
    pathvar1 = OutputLocation + "\\" + name
    gp.AddField_management (pathvar1, "Name", "TEXT")
    gp.CalculateField_management (pathvar1, "Name", 'name2' , "PYTHON")
Holm
LanceShipman
Hi everyone,
Holm
'name2' should be name2.
HolmSeifert
Hallo
Ok i have chaned th e name.
python is running but the field is not calculated
i thing name is defined as string automatically?
O do i need a expressionn?
here is the code:
    name2 = name
    expression = str(raster)
    gp.CalculateField_management (pathvar1, "Name", name2, "PYTHON", "")
HolmSeifert
sorry
I have written a little bit to fast
thanks
Holm
ValentinaBoycheva
Same error message for me. Finally made it work as follows in the command window:
CalculateField SouthPoles junk x PYTHON "x = 'SouthPoles'"
SouthPoles is the name of the feature class, junk is the field, x is the variable and the last expression is the code where the variable x is being assigned a string value, in this case the feature class name.
In the Python script the syntax is:
(fc is the feature class)
fcname = str(fc)
gp.CalculateField(fc, newField, "fcname", "PYTHON", "#")
Note how the parameter fcname is surrounded by quotes - otherwise it won't calculate.
ArcMap 9.3, Python 2.5.1
