It's a single shape file that had approx 12 tiles, then had another 10 added,
and was being appended with another 10 when it stopped being able to be drawn
I've Checked and attempted to repair the Geometry (Results below)
How else might I resolve this?
Could I have been putting too much data into the shape file (They are 2 ft contours) ?
Are there other tools or programs for troubleshooting compromised shapefiles?
Results:
Executing: CheckGeometry C:\0_GIS\PGH_Contour_Files\39001330PAS_cont.shp C:\0_GIS\PGH_Contour_Files\c39001330PAS_cont_CheckGeome.dbf
Start Time: Fri Apr 03 23:00:45 2015
WARNING 000442: bad envelope at 0 in C:\0_GIS\PGH_Contour_Files\39001330PAS_cont.shp
WARNING 000442: empty Z values at 0 in C:\0_GIS\PGH_Contour_Files\39001330PAS_cont.shp
Succeeded at Fri Apr 03 23:00:45 2015 (Elapsed Time: 0.03 seconds)
Executing: RepairGeometry C:\0_GIS\PGH_Contour_Files\39001330PAS_cont.shp DELETE_NULL
Start Time: Fri Apr 03 22:59:54 2015
WARNING 000986: C:\Users\Derek\AppData\Local\Temp\arc7D78\39001330PAS_cont1.txt contains the full list of non simple features.
WARNING 000461: Repaired feature 0 because of Empty Z values.
ERROR 999999: Error executing function.
The geometry has null Z values
The operation was attempted on an empty geometry.
Failed to execute (RepairGeometry).
Failed at Fri Apr 03 22:59:54 2015 (Elapsed Time: 0.08 seconds)
Thanks for your time
Regards,
