A generic error with 'Spatial join', why?
5034
13
12-07-2016 01:04 AM
ronnativ
Hi, after i've used the tool 'Spatial join' in order to spatially join attributes from a line feature to other point feature, recently I get a 999999 generic error when I select 'Closest'. However, these error does not always happen and seldomly I manage to do this. I have used this tool for more than a year and I don't know what could have happen. Recently I upgraded to 10.4.1, but this problem proceed.
I don't know if this relate to another generic Error i get with 'Extract multi-values to points'.
Can anyone help?
Thank you,
Ron
DanPatterson_Retired
try one... perhaps one that you think some locations would meet the criteria... that is what I am trying to determine where optional is optional.
JayantaPoddar
Do both the datasets and the data-frame have same Coordinate System?
Think Location
AbdullahAnter
Honored Contributor
Which tool do you use?
Join data or Spatial join
ronnativ
As I said - Spatial join (the right one)
